Beomaster5 replace hdd
Not Answered This post has 0 verified answers | 27 Replies | 7 Followers
geencar
geencar posted on Sat, Nov 14 2015 8:27 AM
Hi All,
I own a bm5 with origin hdd (500gb version). It is 5 years old now so I want to replace it with a new hdd/1Tb or ssd/512gb
I followed different discsussions here about replacing the harddisk. Seems to work but I think I may have found a better/easier way to do so.
I own an original B&O servictool usb stick and found the option "Clone System Drives"  and  "Clone Entire HDD" which should do the trick. I, do not know if it will work for disks larger than original ones (eg 512gb-> 1Tb)
I am willing to try but I do not have a manual for using the servicetool. Any one who can help out is more than welcome. Also I am willing to share the usb stick. I created an image and restored on another usb stick and as far as I can see it works.
Secondly there's the ssd issue. I downloaded the http://www.crucial.com/usa/en/systemscanner, ran it on the bm5 and I gave me the advise to use the MX100 whichis a true 500Gb ssd
Might work as it offers the the necessary garbage cleanup function (trim is not supported on bm5 system)
If MX100 does the job all other ssd's with Marvel 88SS9174 controllers /MLC controllers should do the trick
Unfortunately these type of discs is leaving the market very fast as newer ssd dries take over.
Any reaction/question/comment is welcome.
austinlally
Would anyone be able to give me a copy of the service tool e.g. as a dropbox link or a disk image I can put on a USB?   askaustin@mac.com
austinlally
Kiran
UK
Kiran replied on Fri, Nov 16 2018 8:37 PM
1. Ensure motherboard is totally fine otherwise its £700 job.
2. Buy hdd/ssd ghoster from Amazon for around £35
3. Buy Crucial MX100 ssd
4. Ghost old hdd to new ssd (copy using ghost machine)
5. My new ssd was 1tb. The old hdd was 512gb. I only have 512gb usable space in new ssd. I’m not bothered. Works lightning quick.
6. Plug in new ssd
7. Switch it on!
Regards
Kiran
Born in NL; I ride ML
beolion
ONLINE
I am using the MX300 1TB and it works without problems.
MX100 can be hard to get a hand on.
gerard
Luxembourg
gerard replied on Sat, Jan 12 2019 8:45 PM
@Kiran
using a bootable usb stick with gparted you may expand the 0,5GB partition to 1TB
regards
Gerard
PS: if someone could share the service tool I would be interested
wantoniak
Hi
If you want to copy/clone current Beomaster 5 drive, the only problems you will have is new SSD drive itself. Samsung SSD and others will not work - period. You have to get Crucial MX300 - 500 or 1Tb drive and just clone old drive to new, cloning 500GB to 1 TB will be no issue. You do not need any cloning devices etc. Put your old BM5 drive in enclose or your computer and clone to a new drive.
If you do not know how to do this take to any computer shops and they will do it. Trust me it is simple job.
Having B&O service tool will help as the system will help you replace drive and will assign serial numbers etc. The tool is not necessary to upgrade the drive by cloning, but it would be helpful to all of us if you want to change motherboard, drive (without cloning) , so if anyone has one please post download link
Aleksei
Russia
Looks like we need to persuade Geencar to share the usb content :)
Since the update server is down, I would consider this as the end of support, that means that we as a community should keep the support in our own group, like we do for Beo5/6.
I join the ask for the shared tool.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+BeoMaster900
gerard
Luxembourg
gerard replied on Tue, Jan 15 2019 10:24 AM
Hi Aleksei,
I think our exchange will better fit here so I'll copy it over from the other threat.
Aleksei:
That may be true if you are experienced to work with linux gparted. When launched, I was afraid to do something wrong while calculating the figures, so I went to more intuitive EaseUS instead, that, unfortunately looks to corrupt MBR. Thus, after extending the disk I performed recovery and update.
I believe the community will be grateful if you would shere step-by-step instruction how to use gparted for this case.
Aleskei
For gparted HDD partion resizing.
get Rufus: https://rufus.ie
get GParted Live bootable image (ISO) according to your processor architecture : https://gparted.org/download.php
Use Rufus to create a bootable USB stick. Video: http://youtu.be/1wDvQRLX4GM
Allow Boot from USB in your BIOS Boot Settings
Boot your PC from the GParted Live USB-Stick
I did this on a PC where I connected the cloned BS5 HDD , I did not work on the BM5 !!!!
You are working on the cloned HDD, if domething goes wrong, you can clone your BM5-HDD once more and start over again.
To resize the partion of the cloned disk from 500GB to 1TB (if your new HDD is 1TB) , in this Video you see how to get the unallocated space to the place where you need it : http://youtu.be/SALU-jmUiuc
an other video for the whole process with YUMI instead of RUFUS:
http://youtu.be/0czAJwEbtFs
hope this helps
gerard
gerard
Luxembourg
gerard replied on Thu, Feb 14 2019 9:10 AM
I changed my HDD to an SSD Model :
Crucial MS500 1TB , worked without problem.
I cloned my original 500GB B&O HDD, I will have to pump the SSD to 1TB, using gparted.
I took some pictures from the swap and will bring a little HowTo once the SSD is repartioned. This is no problem using a PC/MAC with a Gparted Live Stick.
This time I will try it on the BM5, this way there will not be any danger repartioning the PC/MAC HDD instead of the BM5.
I'll keep you informed.
EDIT:
wanted to do this today, but time is missing, this has to wait for 2 Weeks
see you then
gerard
Luxembourg
gerard replied on Tue, Feb 26 2019 10:21 AM
A little update to my repartioning of the BS5 SSD to 1TB, I want to do it on the BM5/BS5 but I'm struggling to get the gparted Live GUI to work.
gParted may be booted on the BM5
gerard
Luxembourg
gerard replied on Sat, Nov 30 2019 9:46 AM
I think the problem comes from the Crucial MX500 not being tealy compatible with the BM5.
I have random boot problems where the BM5 does not see/find the Crucial SSD.
I have ordered a new SSD, a Sandisc ULTRA 3D 1TB and I will report if there are still boot problems.
Stan
Stan replied on Mon, Dec 9 2019 10:21 PM
So far, my Crucial MX? has worked fine for nearly 2 years.  Please report back on the success/failure of the Sandisc in case my Crucial starts flaking out like yours did.
Stan
gerard
Luxembourg
gerard replied on Mon, Dec 9 2019 11:10 PM
For 2 days, there is no problem with the Sandisk ULTRA 3D SSD 1TB.
The Crucial MX500 never worked for a whole day. The wake-up from standby was the problem. I mostly had to power off the BM5 3-5 times in a row to have one boot to complete. once booted it worked fine and fast till the next standby.
I came to the Sandisk after researching the Controller, it seems as if there is also a WesternDigital SSD (a twin of the sandisk) which uses the same controller and also a Plextor SSD with the Marvell 88SS1074
Edit: 25-12-2019
The Sandisk ULTRA 3D SSD still works perfectly
Page 2 of 2 (28 items) < Previous 1 2 | RSS
