The Beosound 5 / Beomaster 5 resources future proof maintenance thread
This post has 69 Replies | 15 Followers
frog
Camberley UK
Posts 569
frog replied on Mon, Dec 23 2019 1:41 AM
Does this actually work?
frog
Camberley UK
Posts 569
frog replied on Mon, Dec 23 2019 1:42 AM
Aleksei replied on Wed, Jan 23 2019 6:30 AM
Here's the link to the BS5Service Tool.
Since this is not a normal file sharing, I do not know how long the link itself will be active, but content should be there.
https://yadi.sk/d/VW3xnEWSWMiikw
https://yadi.sk/d/VW3xnEWSWMiikwhttps://yadi.sk/d/VW3xnEWSWMiikw
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+BeoMaster900
gerard
Luxembourg
Posts 293
gerard replied on Tue, Dec 24 2019 12:07 AM
Yes
Option 2 contains only the service tool image of the USB-stick.
Option 1 has the same image and the software to create a bootable stick with the image.
There is also a Service Manual for the BS5/BM5 and a copy of the image tools website.
frog
Camberley UK
Posts 569
frog replied on Tue, Dec 24 2019 12:38 AM
Thanks, but I get an error writing the USB. I’ve tried 3, though it seems the files are on the USBs. I haven’t tried booting it yet.
frog
Camberley UK
Posts 569
frog replied on Wed, Dec 25 2019 3:27 PM
Thanks Gérard,
got it now. Thanks again!
gerard
Luxembourg
Posts 293
gerard replied on Wed, Dec 25 2019 11:31 PM
Glad to hear that it worked!
here you have a listing of SSDs with the name of their controllers:
http://www.johnnylucky.org/data-storage/ssd-database.html
Michael
Germany
Posts 27
Michael replied on Mon, Jan 13 2020 9:50 AM
Hello,
my name is Micha, I'm from Germany. If any phrase sounds strange, sorry for that, a not native speaker can't do it as well as you can
I am a proud new owner of a Beosound 5 with Beomaster 5, which I could buy used at a good price. I didn't know that the Beomaster runs Win XP, so the first surprise was that I was able to get the system running on my network but couldn't get any internet access at all. All network settings were correct, the system was "visible" in the network but I couldn't get into the internet - no matter what I tried - so no software update for the system was possible, nor could I listen to net radio. The goal was the following:  I wanted to integrate the system in the master link, be able to access Net-Radio, and not use the internal hard disk of the Beomaster, but access my QNAP-NAS as DNLA server.
I am not a very good network expert, but after a few tries I was able to get the whole thing working. If someone else has the problem to not access the internet, I'll post my solution here:
On the Beomaster, as I said, XP runs in the background with an outdated Internet Explorer version (the system was lying unused for 3 years before I bought it...) As soon as on the Windows XP a Firefox version (which is suitable for XP), in addition to the Internet-Explorer was installed, it is suddenly possible to get into the Internet. Then I was able to update the software and also access to the Net-Radio stations was suddenly possible.
The system is running now, I only have to connect it to the Avant 55 in the master link via the converter, then the side rooms should also be able to play music.
So: if someone buys an older Beosound 5 and Beomaster 5 combination and also has problems to get into the internet: in my case the installation of a Firefox fixed the problem.
Micha
bjc64
UK
Posts 2
Silver Member
bjc64 replied on Mon, Jan 13 2020 11:10 AM
Micha01:
Hello Micha
You must feel pleased and elated with your success. Congratulations!
It would be of great interest to know how you installed the software onto the Beomaster5, please. Also, whether you received a display asking to 'log on to Windows' with the user 'Administrator' plus a required password.
Bernard
Michael
Germany
Posts 27
Michael replied on Mon, Jan 13 2020 12:44 PM
Hello,
Okay, let me try to explain. It was not as easy as it sounds now, because I tried different ways (also an update IE, but unfortunately it did not run).
Finally I put the last Firefox that worked for XP (you can still find it on the internet) on a stick and plugged it into the USB port of the Beomaster. With ><>>Go to the service menu, call maintenance, then you have the Windows interface. The stick is recognized as an external drive, then drag the software to the desktop and install it. There is no query about the administrator or password.
Micha
Michael
Germany
Posts 27
Michael replied on Mon, Jan 13 2020 12:53 PM
Sorry: „><>< Go“ is correct
bjc64
UK
Posts 2
Silver Member
bjc64 replied on Mon, Jan 13 2020 6:27 PM
Micha01:
><>< Go“ is correct
So you accessed the Windows Service Menu and by using a keyboard and/or mouse installed the software? Is windows service pack 2 or 3 installed?
When you exit the Service Menu does it load up the BeoSound5 user interface? For myself, when I exit the Service Menu  I have to 'log on to Windows' with the user 'Administrator' plus a required password. This is something that has happened in recent months.
Bernard
Michael
Germany
Posts 27
Michael replied on Mon, Jan 13 2020 6:41 PM
It is servicepack 2. After leaving  Windows the normal overview is shown. There is no need to lock in. I haven‘t had that situation to lock in as an admin with password.... sorry, but therefore i‘am not able to give you any help... maybe the systems are a litle different (i don‘t know).
For me it was realy clear that the problem was the old version of the IE. So i thougth about how to bring the system online  - and Firefox was the way....
Michael
Germany
Posts 27
Michael replied on Mon, Jan 13 2020 6:42 PM
beolion
Posts 470
beolion replied on Tue, Jan 14 2020 8:27 PM
Hi
I never connect a screen and keyboard to my system as the BS5 is in the kitchen and the BM5 is in the office and connected with 9 metre cables.
To manage the BM5 I am using TightVNC to make a remote connection to the system. It works very well and other users are doing the same.
You still need to start in Maintenance Mode on the BS5 though.
Sjock601
United States
Posts 38
Sjock601 replied on Wed, Jan 15 2020 1:10 AM
       My BeoSound 5 system is also getting close to 10 years old.  I still love the design and how it functions.  Love MOTS and  I am always listening to music from my personal collection as well as the radio. Really like not having to pay for a streaming service but still able to enjoy nice music.  My internet service was recently down (which tends to happen a lot and is totally unreliable) for 2 days.  I had no landline phone, internet or TV or radio for two days, but I could still enjoy music just like a streaming service.  I just hope that I can keep it running for a long time.  Would be nice if B&O would write new software to make it work it work even better, which can be done.  I thinks there are enough BeoSound 5 systems out there that it would be a source for a considerable monetary gain for them.
        However, on the. negative side, there were so many software changes made to the system after it was introduced that it is really, really NOT THE SAME SYSTEM THAT I INITIALLY PURCHASED.  That is really frustrating and really makes me skeptical in regards to future investments into B&O products.  Some of the changes were for the better, but there were more things removed than added.  I am still trying to understand the thinking for these issues.
MJBeo
Netherlands
Posts 259
MJBeo replied on Wed, Aug 12 2020 2:32 PM
Super old thread but this became relevant for me this week.
BeoMotion:
Today I had a look at the BeoSound 5 USB communication.
Quite easy and straightforward.
Wrote a little program and hooked up the BeoSound 5 via USB and HDMI to a Raspberry Pi.
BR,
BeoMotion.
Would you be so kind to share this with me?
Beosystem 5500    BV7-32 MKIII + BL14.4 + MCL2P & CX100    AppleTV4 + Lintronic -238    4 link rooms with MCL2 A / MCL2 A/V + RL60.2 / CX50 & Cona / S45.2    Various Vintage restore objects
maki82
Posts 17
maki82 replied on Thu, Oct 15 2020 1:06 PM
Hi guys
Couple month ago I bought a house where a lot of MasterLink cables are in it. Because of that, I bought a Beomaster 5 and a Beosound 5 with 2 Beolab 8000 and 1 Beolab 3500. Everything seems to work well, I connected the BM5 with my router and I got some web music.
Now I tried to install the whole system in the house. I connected everything and tried to listen to the web music. Unfortunately the screen of the BS 5 went black and the music stoped even if I hear that the BM 5 still is running. I made a restart with the main button on the BM 5 and after the system runs again, I listened again to web music and after around 4-5 Minutes the screen went black again and as well the music stoped.
Couple days later (today) I turned on the whole system and figured out that everything works well as long as no music is playing. The system runs very stable and no surprises. But as soon as music is running the screen went black and the music stoped.
Does somebody of you has an idea what it could be? Would really like to keep the system and to listen some music in the house.
Cheers, Mario
lechatsurletoit
Posts 37
could it be a short circuit in one of the masterlink cables?
Are the beolabs 8000 directly plugged in the beomaster or in a seperate room wih a beolink active and IR eye?
maki82
Posts 17
maki82 replied on Thu, Oct 15 2020 2:38 PM
lechatsurletoit:
The Beolab8000 are directly plugged in and just the Beolab3500 is via ML ... but I tried other cables and other ML cables.
Now I am testing every thing just via the ML and BL3500.
But still the same - black screen and no reply on any action except the main pwr button on the BM5 🤔
beolion
Posts 470
beolion replied on Thu, Oct 15 2020 3:39 PM
Do you have the same problem if you don’t connect BL3500?
Is the BS5 set to audio master and with correct option?
lechatsurletoit
Posts 37
Did you try just the beolab 8000 without the masterlink?
Is the beomaster set as a master? Is it in option 1 or 2?
lechatsurletoit
Posts 37
Jinx
maki82
Posts 17
maki82 replied on Mon, Oct 19 2020 8:15 PM
I opened the BM5 ... for me it looks like one condensator is burned ... but I‘m not a pro, maybe somebody of you sees something else.
riverstyx
SouthWest UK
Posts 934
riverstyx replied on Mon, Oct 19 2020 10:59 PM
Yep, that capacitor certainly doesn't look happy, and the one next to it looks like it is bulging too (although it may just be the way the light is reflecting in the photo).
The electrolytic capacitors are the usual culprits when the BM5 is shutting down randomly or refusing to turn on. They can be replaced, but it's not as easy as it might seem - it's a multilayer PCB and at least one leg of each of those caps will be connected to the ground plane which acts like a huge heatsink, drawing away all the heat when you try to desolder the old caps.
It's an easier task if you can pre-heat the board, but this maybe a little outside the scope for a lot of DIY soldering setups - without pre-heating it can be a real struggle to clear the holes without damaging the pads or through plating.
Martin.
maki82
Posts 17
maki82 replied on Tue, Oct 20 2020 9:38 AM
It seems like there are 2 more capacitors which are not ok, just on the other side of the cooling unit.
I am going to give a try and to replace them, I mean if it‘s the reason why the BS5 screen is going to be black and the music stops than I‘ve no choices - repair the installed mainboard or replace it with the Epia EX 1.5GHz because it looks like it works more reliable. But first I try to repair the capacitors.
Edoardo
San Marino
Posts 151
Edoardo replied on Thu, Nov 5 2020 3:31 PM
Totally agree with you. I have had lots of troubles with my BS5/BM5 in the first times; now it works fine, but I need to replace the original HD 1 Tb capacity with a 2 Tb, if possible.
Let's keep in touch
Edoardo
Edoardo
San Marino
Posts 151
Edoardo replied on Thu, Nov 5 2020 3:36 PM
Hello Martin, I think you did an excellent (and corageous) job.
I need to do the same, so I hope you will help me in case of trouble.
Regards
Edoardo
riverstyx
SouthWest UK
Posts 934
maki82:
If you haven't already tried the replacement you might consider trying to cut the existing capacitors out whilst leaving as much of their legs protruding from the pcb as possible, then solder the legs of the new caps to these. This will probably mean securing the new capacitors to the board on their side with some silicone - this will mean you don't have to worry about desoldering the existing caps and avoid any potential damage to the plated holes (be sure to use neutral cure silicone if you go down this route though, as normal silicone releases acetic acid which can damage the pcb and nearby components during curing).
Kind regards,
Martin.
maki82
Posts 17
maki82 replied on Fri, Nov 6 2020 7:37 PM
Hi Martin
No I didn‘t yet fixed the issue and it seems like I‘ve to wait the next couple weeks because I‘ve to do some stuff for work.
But thank you for the idea, I thought it‘s going to become complicated but it looks like it could be fixed in a easy way ... we will see Stick out tongueWink keep you updated as soon as I‘ve time to fix it.
Jack
Poland
Posts 15
Jack replied on Fri, Feb 19 2021 12:24 PM
SMBCFG Write Serial Number BeoMaster 5 to BIOS
Run SMBCFG.EXE from usb boot stick. Enter the serial number in the tabs: System, Base Board, Enclosure/Chasiss
SMBCFG.rar
Page 2 of 2 (70 items) < Previous 1 2 | RSS
