Remote in link-mode?
Not Answered This post has 0 verified answers | 6 Replies | 2 Followers
Stones
Stones posted on Thu, Apr 2 2015 7:32 PM
Hi
The AV Terminal might locked in link mode for operating link products in link option 4. An L appears on the little display. Is it possible to lock BeoLink 1000 or Beo4 in a similar way, or do I have to press LINK every time?
Best regards
Steinar
tompa
tompa replied on Thu, Apr 2 2015 8:38 PM
with beo 4 new model with joystick you can lock it to linkmode with zone,and with some older beo4 you could lock it with a "secret" code to link mode
but was long time ago i use it so i don't remember how, but will try to see if i can find it somewere...
Emil
Emil replied on Thu, Apr 2 2015 8:39 PM
On Beo4 go to config (standby button + list) and then press 2002. Not sure about BL1000.
Millemissen
Flensborg, Denmark
@Emil,
for those, who want to 'try this out', please do tell, how to reset it again.
Emil
Emil replied on Thu, Apr 2 2015 9:02 PM
Oh, sorry! Missed that... As far as I remember it would actually be the same combination. I use it for one of my own tv's that are a bit close to one of the others. Beo4 are really powerful remotes.
Stones
ThanksSmile
Guy
Buckinghamshire
Guy replied on Wed, Sep 18 2019 2:20 PM
An old thread I know, but I have a couple of questions about the Beo4 'link-mode'.
I just set up a BC6-23 in my bedroom.  The bedroom overlooks the lounge (which contains my BC9500), so I put the BC6 in V.OPT 4 so that I could put a Beo4 in 'LINK' mode (as explained above) to control it without affecting the BC9500.
It works fine, but I have two questions:
- Does LINK-mode reduce the IR power of the remote?  It seems to be much more directional now.
- Should I be able to use the 'link-mode' Beo4 to still control the BC9500 by selecting/pressing 'LINK' before the control?  I can't get this to work, and it would be useful for when I want to lean over the balcony and control the BC9500.
Page 1 of 1 (7 items) | RSS
