Beovision 11 Easel Stand Instructions...
Answered (Verified) This post has 1 verified answer | 13 Replies | 0 Followers
Sal
California, USA
Sal posted on Mon, Jan 26 2015 4:30 AM
Hello,
I figure this has an easy answer, what does the following step in the installation instructions mean? I'm sure it would be obvious if I had the stand in real life, but right now, my curiosity is piqued.
Beoberg
Odense, Denmark
Verified by Sal
The easel stand has a compartment for the two weights pictured (the are heavy as ****!!). The picture shows how the weights must fit in the compartment.
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
tournedos
Finland
I hope whoever drew that diagram will never move to Ikea Confused
Now I can't get any peace either!
--mika
Beoberg
Odense, Denmark
Verified by Sal
Sal
California, USA
Sal replied on Mon, Jan 26 2015 2:38 PM
Thank you! That makes perfect sense.
moxxey
South West, UK
moxxey replied on Thu, Mar 26 2020 11:29 AM
Sorry for dragging up an old thread, but I've just (finally!) found a BV11-40 easel stand to take my BV11-40 off the wall and on to the floor. I had dealers offering one for £400, but this was too much for an old TV, so managed to find one for £80, pre-loved.
Problem is....no instructions. Anyone have the instructions for the BV11-40/46 easel stand installation?
Beozip
maybe this is helpful ...
https://forum.beoworld.org/forums/p/27897/220342.aspx
good luck
moxxey
South West, UK
moxxey replied on Thu, Mar 26 2020 6:00 PM
Beozip:
Thanks. I think my kit doesn't have the screws, which is slightly concerning!
Aussie Michael
Melbourne, AU
moxxey:
I bought an easel stand from a B&O store (floor model) but it didn’t come with screws either and then they closed so I never set it up on my BV 14. I even have a brand new wall bracket too but that’s in a box and I’m yet to hang it on the wall,
Someone told me you can get two compatible screws from the hardware
Does anyone have the dimensions of those screws?
RaMaBo
near Munich
RaMaBo replied on Fri, Mar 27 2020 11:37 AM
the required screws are  6 x 20mm according to the Service Manual. And B&O being an enterprise settled in the metric 'universe' i'm quite sure it's a M6 x 20 screw Smile
Ralph-Marcus
moxxey
South West, UK
moxxey replied on Fri, Mar 27 2020 3:12 PM
RaMaBo:
6 screws? I thought there was only 2!
I guess these would do the trick? https://www.accu.co.uk/en/cap-head-screws/3869-SSCF-M6-20-A2?
RaMaBo
near Munich
RaMaBo replied on Fri, Mar 27 2020 3:35 PM
No only two are needed.
They are described as M6 x 20, M stands for metric, 6 (mm)  for the diameter of the thread and 20 (mm) for the length of the threaded shaft.
Those screws you sent the link for should do it quite well SmileThumbs Up
Ralph-Marcus
moxxey
South West, UK
moxxey replied on Fri, Mar 27 2020 3:47 PM
RaMaBo:
They had a min order of 100 Big Smile
I found some on Amazon though - ordered! Thanks for your help. Will let you know how I get on once the new stand arrives next week.
Aussie Michael
Melbourne, AU
I’m looking forward to see how it goes Moxxey as I will need to buy those screws at a point in time too
moxxey
South West, UK
moxxey replied on Sat, Mar 28 2020 12:56 PM
Aussie Michael:
Will let you know by next weekend!
I did have a BV11-55 on an easel stand a few years ago. Wasn't too hard to construct, from what I remember.
Page 1 of 1 (14 items) | RSS
