Beocenter 7007 turntable problem
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
shadowline
shadowline posted on Fri, May 25 2012 1:48 PM
Hi.
Ive bought a beautiful Beocenter 7007 which sounds gorgeous and really powerful.
Everything works perfectly except the turntable
Basically if you hold the start button down the turntable goes at the correct speed on 33 and 45 but as soon as you let go it stops.
I presume there is some kind of relay somewhere that is supposed to switch to keep it spinning?
Any pointers before I begin to strip it down would be good,
Thanks in anticipation
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Fri, May 25 2012 4:03 PM
Press PH to start playing records.
The other thing is for cleaning records.
- Get the user manual !
shadowline
Really?
You are kidding?
Ill give that a whirl later, thankyou :)
Page 1 of 1 (3 items) | RSS
