LCS 9000: will it work with N.Music and N.Radio?
This post has 6 Replies | 3 Followers
TWG
Posts 1,617
TWG Posted: Thu, May 24 2012 10:21 PM
Hello,
will an old LCS 9000 work on a Beosound 5 via ML connection and N.Radio and N.Music?
thanks
frog
Camberley UK
Posts 580
frog replied on Thu, May 24 2012 11:41 PM
Yes it will, but you have to upgrade the microcomputer in the unit. It is quite an easy job so you could do it yourself if you are OK with a screwdriver. The instructions on how to do it come with the part. Expect to pay about £50 for the micro controller.
Keith Saunders
Hampshire, United Kingdom
Posts 5,480
You may wish to see the FAQ on the Beoworld web site HERE which gives complete details and HERE to install the PCB
Regards Keith....
marko777777
Posts 3
I think if the only difference will be that A.TAPE2 or PHONE will appear on the screen instead of N.MUSIC or N.RADIO.
The N.MUSIC compatibility is more about the Audiomaster.
TWG
Posts 1,617
TWG replied on Sun, May 27 2012 1:33 PM
Thank you for the helpful answers. Did I read correctly, that every LCS9000 will be able to function correctly in a Masterlinknetwork after removing the plastic from the ML socket that exists in EVERY LCS900?
Keith Saunders
Posts 5,480
You DID read correctly.
Once you have removed the black plastic cover and followed the simple procedure to change from MCL to Masterlink as defined in the FAQ, then you effectively have a Beolab 3500. Subsequently if you upgrade the software to version 2.1 by replacing the microprocessor, then N.Music and N.Radio will appear on the screen when selected.
You now have a 100% compatible Masterlink product.
Regards Keith....
TWG
Posts 1,617
TWG replied on Tue, May 29 2012 9:20 PM
Good evening and again:
thank you all for your help. Smile
Keith, the technical B&O side on the forum would be nearly dead without you.  You often help us with technical problems: A big thank you for this!
Page 1 of 1 (7 items) | RSS
