Beo4 with LC2 controlling light/lamp
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
leosgonewild
ONLINE
Silver Member
leosgonewild posted on Tue, Dec 2 2014 4:04 PM
I have two LC2´s in the same room.
They are set up as "lamp1" and "lamp2".
When I press "light" on my beo4, I have to press list 9 times before it shows "lamp" in order for me to choose what lamp to control.
I want to move "lamp" to show first when I press "list" after pressing "light".
"Lamp" doesnt show in the menu at all when I go into the setup of the Beo4.
Anyone that can help me with this?
mjmedlo
Get in to the menu for the beo4
Select 'move'
The press light in the beo4 menu and it will move to the front.
tournedos
Finland
Unfortunately older Beo4s don't have the MOVE function. I believe you can circumvent this by deleting everything from the list and then adding the functions back in the desired order.
--mika
leosgonewild
ONLINE
Silver Member
Mine supports the move function.
I did a reset Smile
valve1
The south of France and occasionally Dublin Ireland
My beo4 when you press light once it shows light and works fine with LC2/3
Page 1 of 1 (5 items) | RSS
