Beoremote one Light commands
Not Answered This post has 0 verified answers | 18 Replies | 3 Followers
mjmedlo
mjmedlo posted on Mon, Aug 18 2014 12:38 AM
All,
The beoremote one allows several buttons under 'light' I.e. Morning night movie, etc.
I can not make these commands show up anywhere.
I am wondering if anyone is using the light buttons for anything.
My idea is to send these commands and see on the monitor in the blgw what they are actually being received as.
I'd like to build some macros around these.
Thanks all!
stefan
200 miles from Struer
stefan replied on Mon, Aug 18 2014 5:00 AM
LIGHT commands MORNING, TV, LEAVING....are actually FUNCTION_1-10 commands in the MLGW.
I think it's the same in the BLGW. Similiar to commands in CONTROL mode (WINDOW....).
You will find detailed information on the Lintronic site.
http://www.lintronic.dk/AppNote_BEO4_navi.pdf
Stefan
mjmedlo
Now the question on the beoremote one is how to get the sub menu up on the remote.
I can get light but no submenu where I can select the morning night, etc.
Any help is appreciated.
Carolpa
list - settings - advanced - light - show;
then choose your settings
mjmedlo
Carolpa:
I have done that but I still can not get te sub menu to pull up under an av command.
Carolpa
mjmedlo:
Carolpa:
list - light - OK - list
does the trick
mjmedlo
Thanks!!!!
Millemissen
Flensborg, Denmark
ONLINE
Carolpa:
does the trick
I love my Beo4 Smile
Carolpa
Millemissen:
Carolpa:
does the trick
once a One then always a One
and this are not the same commanda as on the Beo4
Millemissen
Flensborg, Denmark
ONLINE
1: I  guess there are pro and cons by the One!
2: No - of course - they are preprogrammed (from the MLGW) and named.  A Beo4 only gives you numbers - but it is faster (if you can remember which numbers are which scenes).
mjmedlo
They're not really preprogrammed...they just have a name on the beoremote one.
They're simply function1,2,3 etc. But can be named whatever you like
The same result occurs by pressing light then a number. The names are just convenient for scene recollection.
Millemissen:
Hiort
Sweden
ONLINE
Hiort replied on Thu, Mar 5 2015 3:50 PM
Just got the Beoremote One.
When I choose Light, I can put the light on by pressing the play button, and switch off by pressing pause button.
I can select preset modes by pressing a number.
I can dim by pressing arrows up and down.
But:
Is it possible to configure the presets I have made for my LC2s (1, 2, etc) to eg the preset names like "goodnight" etc in Beoremote One?
Cannot find any options for that.
f5434964
Austria
Hello!
Anything found yet? I am thinking on buying a LC1 or LC2 and want to control them with the beoremote 1 like using a beo4 - is this conveniently possible?
thanks
Elmar
Hiort
Sweden
ONLINE
Hiort replied on Sat, Jul 2 2016 10:13 AM
f5434964:
Hello!
thanks
Elmar
Well, not really. I mainly use BR1 to switch my LC2:s on and off, and of course dim. Have problems selecting presets and particular lamps.
f5434964
Austria
but you obviously can switch on/off with BR1?!
Page 1 of 2 (19 items) 1 2 Next > | RSS
