bottom glass panel on beocenter 9000
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
dovbrener
dovbrener posted on Fri, Apr 25 2014 11:03 AM
The bottom glass panel on my beocenter 9000 has come out and i am having problems getting it back in. the little backers have come out of their locators. should they brackets be locked in?
Any tricks, ytube videos, any other help would be appreciated.
Dillen
Copenhagen / Denmark
Dillen replied on Fri, Apr 25 2014 3:22 PM
Welcome to Beoworld !
The service manual will point you to the screw from below at the bottom left corner.
It will also show you how to push the whole panel a centimeter or so sideways to release and lock back in.
dovbrener
Hi Martin,
Thank you for a prompt reply. I have researched the information on the internet, found the screw at the bottom left hand side, re glued the glass and the frame, then slid it back into position and screwed the screw back. Works great now. I used a silicone based glue.
Can you point me where I can find the service manual please. I found one but it has only the electronics diagrams in it.
I still get a bit of noise from the CD door at the end of the opening cycle.
Thank you again for your help.
Dov
Page 1 of 1 (3 items) | RSS
