Beolab 8000 - recloth frets for less than 10GBP
Not Answered This post has 0 verified answers | 12 Replies | 1 Follower
riverstyx
SouthWest UK
riverstyx posted on Thu, Apr 3 2014 11:22 PM
I have just finished recovering the frets on my pair of BL8000 and thought I should share some pics..
I used a pair of 60 denier tights (pantyhose) - 40 denier is probably a marginally better match for the original fabric and was what I was going to use originally, but the ones I bought had a thicker reinforcement area near the top of each leg and would have been a little short if I'd cut this area off. 60 denier is still a very close match to the original fabric though and I'm very happy with the results.
Items required:-
ten 5mm x 5m rolls of double sided tape (2.99 GBP from ebay)
6.00GBP for three pairs of 60 denier tights (tesco)
A pair of scissors
(actually, the above is sufficient to re-cover three pairs of speakers, and one 5m roll of tape is sufficient if you are very careful about wastage)
1. Detach frets from speakers and remove existing cloth
Affix double sided tape to frame
Cut one leg from tights, remove backing from double sided tape, and slide the leg of the tights over the frame. I found it best to slide it on from the bottom of the frame leaving the toe of the tights at the end with hole for the LED - this means you have more fabric to work with around the top plate.
I then tied the fabric at the top to keep it in place whilst I worked and to ensure I had enough fabric at the end when it came to dealing with the top part.
Start cutting the fabric at the rear of the frame, starting at the bottom and press the fabric against the double sided tape as you go - this helps ensure the grain of the fabric remains square to the frame
Finally, remove the tie from the top, and maneuver the top part of the fret into place and the dress the fabric around it.
Trim off the excess fabric (cutting with scissors whilst stretching the excess fabric away from the line of tape results in a nice clean finish)
Reinstall the completed fret and you're done. Time taken approx 45 mins per speaker - and probably only 30 mins if you're not stopping to take photos Smile
Apologies for the poor quality photos, but taking them was a bit of an last minute decision - my digital camera wasn't charged and my mobile is in for repair so I ended up using a rather old camera phone.
Thanks and credit are due to Leslie for the inspiration of using tights for the re-covering.
Martin.
DMacri
United States
That looks like a beautiful job. Great work.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Leslie
the Netherlands City
Silver Member
Leslie replied on Mon, Apr 14 2014 7:06 AM
Perfect Martin, skills you have and that for less then a tenner.
Brengen & Ophalen
kl366
kl366 replied on Tue, Feb 26 2019 4:31 AM
This looks great! I’m trying to do this too, may I know where do you place the double sided tape? Just within the interior of the frame?
riverstyx
SouthWest UK
Yes, all around the perimeter of the frame, on the inside, which is the same place that the original fabric is attached.
Best regards,
Martin.
mbolo01
Annecy - France
Great job! I recently acquired a set of BL 8000 and I wonder how to remove the frets?
9 LEE
Eastbourne, UK
Absolutely brilliant!  Top workmanship and a great idea. I never actually thought of putting a pair of ladies tights on some 8000's, so kudos for thinking of such a low-cost solution.
I'm not sure what the next step is for your 8000's after this.  What about replacing the iron bases with these? LOL !!
joeyboygolf
Ely, Cambridgeshire, UK
Surely the speakers will be too close together to achieve the correct stereo spread!
Regards Graham
gerard
Luxembourg
did you also replace the acoustic foam?
samsp
samsp replied on Sun, Sep 8 2019 10:44 PM
Any recommendations on the type of double sided tape?
riverstyx
SouthWest UK
I just used the tranparent craft stuff which usually has a red backing.
ed7
ed7 replied on Mon, Sep 9 2019 10:51 AM
Yes excellent solution for the beolab8000 if you have a tight budgetBig Smile
Puncher
Durham
9 LEE:
Unsure - Are they yours???UnsureUnsureErm..
Ban boring signatures!
Page 1 of 1 (13 items) | RSS
