Reply To: Update avant hdmi?
#9987
scanorama99
  • Topics Started 5
  • Total Posts 9
Thanks Guy, I have sent them a message, appreciated!
I am not sure, perhaps there is a way to improve my settings as well?
Is there a reason this delay black screen shows for 6 seconds on every move I press play on? Is not the preview screen with the text about the movie in a certain frame rate as well? I thought this black screen was due to switching between different frame rates but if so 0% of the netflix movies has the same frame rate as the netflix’s general interface with all the preview screens, or?
The tv is located in sweden so I guess it is set to 50hz (I saw a setting for this in an older beovision 4 but on the avant no such setting that I see that I can edit).
I can set the apple-tv external box to either SDR 50hz or SDR 60hz
But it does not seem to matter if I set 50 or 60hz when I have the “match frame rate” on, it seems to do this handshake frame checking every time I play something.
