Reply To: New product launch – beosound theatre?
#9977
Steve at Sounds Heavenly
  • Topics Started 18
  • Total Posts 171
Yes, you can add ANY speakers, but passive Beovox speakers will require a power amp such as BeoAmp2 in order to connect to the Theatre. I don’t recommend using Passive or MCL2P as there are issues with correctly triggering these amps from newer B&O products with RJ45 outputs. The Theatre will be able to carry out room compensation with any passive speakers connected via any type of power amp, but it won’t have the acoustic profile of the speakers stored for magnitude and phase correction (unless you are using Beovox 1 or 2 speakers).
Kind regards, Steve.
