19 October 2022 at 08:02
#26259
If you are happy to keep using the BeoLink Passive to drive your speakers then there is no need to change.
There is no specific need to keep ML. Simply use the Beolink Passive’s PowerLink input and treat this as you would any other Active speaker.
If you need separate control of the bathroom speakers, then add an NL source with a Powerlink output.
