Reply To: BeoLink Passive
#9912
Millemissen
  • Topics Started 7
  • Total Posts 263
I am not sure what you want to do – where does the gateway fit in?
Maybe you mean the Converter….and speaker connected to this?
If it is just about amplifying, the amp that B&O offers is called Beoamp 2 (which is pretty expensive).
From Atlona there are amps, that could be an alternative to this, but still rather expensive.
Basicly you could use any small and cheap digital/Class C amp.
You can get some without volume control – but even with a volume control built in, you’d just have to turn them up to a fitting volume and leave that so. They won’t consume much power anyway.
