Reply To: Beomaster 1700
#9880
Glitch
  • Topics Started 9
  • Total Posts 81
The best and most reliable option is to replace the connectors. However, you will likely be fine with just protecting the newly cleaned connector so it doesn’t re-oxidize quickly.
A light coating of Deoxit is most likely all you need. Any light oil would also work in a pinch.
Another option is to “tin” the connectors with a very light coating of solder. If the pins are brass, this is quite easy to do.
I would start with one of the above options, then if the issue returns, go though the trouble of replacing the connectors.
Glitch
