Reply To: Repaint Beolab 4000’s
#9844
Die_Bogener
  • Topics Started 1
  • Total Posts 97
The aluminum is eloxated. Very hard oxyd. Cannot be painted, no paint will stick on this oxyd. It will chip off easily…
You have to grind it, better is sandblasting with glas, not sand or steel.
As mentioned right before: you need a etch primer, then aluminum can be painted.
On the etch primer you can use almost every car paint… 2K.
