Reply To: Beogram 4004 (Type 5526) Issues
#9826
Mark-sf
  • Topics Started 0
  • Total Posts 123
I am having trouble parsing the symptoms you are reporting. In normal operation, simply pressing start momentarily will cause the tonearm to move to the edge of the record and lower. If you press and hold then it will continue past that point until you release.  Pressing 33 should just cause the turntable to spin for cleaning without the arm moving. If it is then you may have a shorted transistor in the servo motor control section. You can see a table of voltages on the schematic available at https://beomanuals.com/manuals/Beogram/Beogram%204004/Bang-Olufsen-Beogram_4002-4004-Schematic-2.pdf.
  • This reply was modified 1 month, 3 weeks ago by Mark-sf.
