Reply To: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive
#9804
Die_Bogener
  • Topics Started 1
  • Total Posts 97
Check this board and the LED board for broken solder pins/pads. Especially the ground pins… and use a magnifying glass… BL8000 have lots of problems with broken pads. More or less ALL active loudspeaker have this problem. Sound is stress to solder pads, it’s mechanical stress and it is just a matter of time and played volume…
… and for the acid foam. Maybe broken lines in the preamp section…
  • This reply was modified 1 month, 2 weeks ago by Die_Bogener.
