15 October 2022 at 19:40
#26351
Captains log, stardate 2022:
There are notes in the 2nd half of the SM that explain orientation for installing some of the gears. Easy to miss, as you need to skip past all the other language versions of part 1. Usually manuals have each language’s contents organized together?
I pulled it all apart & installed the gears according to the manual, x2 checked with pics I took before disassembly.
Fuse is still good, so I suspect I need to rebuild the piston, using condor audio’s doc for reference.
