Reply To: The best choice for your first B&O speaker?
#9772
Steve at Sounds Heavenly
  • Topics Started 18
  • Total Posts 166
That looks awesome!
Yes, you can use the Beosound 1 as a speaker with a system that has DIN or RJ45 Powerlink outputs via these cables (you will need to turn the Beosound 1 to Aux manually as it doesn’t auto-sense on the Aux input):-
DIN Powerlink (1990-2012): https://soundsheavenly.com/tv-masterlink-control-and-sync/15-264-datalink-cable-for-bo-beocord-etc.html#/9-length-18m
RJ45 Powerlink (2013 on): https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/84-378-rj45-to-aux-input-cable-add-core-essence-or-playmaker-to-your-bo-system.html#/9-length-18m
Kind regards, Steve
