Reply To: The best choice for your first B&O speaker?
#9747
Millemissen
  • Topics Started 7
  • Total Posts 265
Apart from the fact that FM radio – where I live – is almost dead, the only and main drawback of this unit is, that the AUX has no autosense.
I’d prefer to use the headphone out to a Playmaker’s line input…..which has line sense.
And then connect a set of e.g. BL8000’s there.
This way you – in addition – you are able to use the AUX of the BS1 for a turntable or maybe even for a small tv!
Even better would be to use an Essence MK2/Core – this way you could  transfer the CD playback (and the sound of an optional vinyl player) to a modern NL/Mozart based setup in the home.
If this just is about a simple ‘first time B&O unit’, I’d personally recommend the Beosound 8 instead of the BS1.
This has autosense on the Aux/line-in…..which makes it very handy, if you connect an Airplay/Chromecast/BT device there.
And it should come with its own small remote control.
The BS8 is in my opinion a very underrated unit.
  • This reply was modified 1 month, 2 weeks ago by Millemissen.
