15 October 2022 at 09:08
#26376
I will have another check at those set of contacts (as I have done before).
the BC119 transistor is on order, heatsink I got – that should not be too hard, only takes time until it arrives.
fairly confident the 0TR4 = Tip41 is ok. I had another good run, basically no problems
until the sequence came to an end with the carriage moving in, stops -as described- but no lowering…..
ALF
