Reply To: New Halo firmware at last…. Version 1.5.930
#9656
LeMirage
  • Topics Started 6
  • Total Posts 48
With previous Halo firmware 1.5.930 the battery life was pretty good, almost a week with daily use. With the latest firmware we are back to the horrible battery life of the initial firmwares after product release again….:( Only thing added with the latest firmware according release notes was Theatre support. No clue why the battery consumption is back to HUGE now…. Would suggest anyone with a Halo table version to file a bug report from the app, hopefully it helps. I have the Halo on a Qi pad but do drag it a lot around the house so hopefully the battery drain issue is fixed soon.
I may have found something interesting in my setup causing the Halo wifi connection issues…..
Testing upcoming days and will report back here.
