Reply To: Beogram 8002 stops short
#9480
antlestxp
  • Topics Started 1
  • Total Posts 8
Got it up and running. Circled back to the basics. Checked my solder work. Pulled as much as the old solder my vacuum could. All new solder. Cleaned and checked all mechanicals. Then checked my work and calibration of the control panel. It was the control panel. My adjustment was close but not close enough. Had the relocate the new receivers into a better position then readjust with the screws. Soldered a connector to the panel I could leave measuring equipment to made quick work of it. Now I just need to finish up the rest of the adjustments to the tone arm.
Thanks again. This is my 4th and probably final beo. RX2 TX2 4002 and now this 8002. Every table I have wanted over the years.
8002 up and running
  • This reply was modified 2 months ago by antlestxp.
