Reply To: Beo6 Best Practices
#9310
Guy
  • Warwickshire, UK
  • Topics Started 10
  • Total Posts 396
is the software “open” to access without a temporary login as the on e the installators used to have?
When you open the configuration tool, you tick the ‘work offline’ check box and then you won’t need a password.
