Reply To: Three generations of link-system
#9251
Guy
  • Warwickshire, UK
  • Topics Started 10
  • Total Posts 396
If it doesn’t have a built-in RIAA
If you do need to look inside the Beomaster, I now know where the RIAA board would be fitted! It’s rear left of the pre-amp PCB, fitted vertically about 5 cm inboard of the antenna socket. To see if you may have to pivot the Tuner board upwards into its service position.
If you look carefully at this eBay listing, on the bottom left of the fourth photo you can see a row of holes labelled ‘RIAA’ (just visible!) into which the board would be soldered: https://www.ebay.co.uk/itm/255129827540
Good luck with the move to Spain!
