Reply To: Three generations of link-system
#9095
Sia43
    • Topics Started 13
    • Total Posts 75
    You could get rid of the BL1611 by using an audiomaster such as Beosound Ouverture, which as far as I know is the only Beomaster with both ML and datalink.  However, you would still need an RIAA stage.
    That would be a good option as it is much easier to find an overture out there than a Beomaster 6500 or 7000. Can overture control Beogram and command it to play, Stop, pause, skip forward or backwards? It seems like Overture doesn’t have a dedicated phono button, but AUX. will the Beogram understand that it is connected through AUX with full functionality?overture
