Reply To: Can I block WISA connections to my beolab 18’s?
#9068
Beouser66
  • Topics Started 0
  • Total Posts 7
Are you sure..??
if you use powerlink the switch on bl18 is set on either L or R and then wisa is disabled
so a correct explanation of your setup would
be nice..
