Reply To: Three generations of link-system
#8990
Carolpa
  • Topics Started 3
  • Total Posts 84
Many thanks, Guy and Carolpa for your responses, which are highly appreciated. I will give solution 2 a try as I don’t own a Beomaster yet. If I’m reading your response correctly, the second solution allows for the connection of a Beogram, directly to the ML-network (using a BL-converter), without needing a Beomaster 6500 or 7000. It would still be good to understnad the difference in link signal between the signal from Beogrma to BL-converter to ML in one hand and Beogram to Beomaster to BL-converter to ML Will the signals be different?
You interpret my reply incorrectly. The Beomaster is needed.
you can’t use solution 1 or 2 without the first part of my post.
  • This reply was modified 2 months ago by Carolpa.
