25 September 2022 at 03:26
#26889
Thank you very much for trying to help – much appreciated !
i really don’t know what the current draw is or should be in that circumstance.
the way I tested or checked was to isolate a possible transformer issue from the rest of
the deck by unplugging P2 & P3 which are supplying the rest of the deck, in other
words the only connection from the power supply to the main deck.
so, it is really only the power-pack (transformer) connected to board 3 which should
deliver the 5V, 14.8 V and 15.5V supplies for the deck but it doesn’t.
there one last thing I will try and report back.
ALF
all main components involved have been tested off-board.
