September 20, 2022 at 11:22 am
#8840
In my experience B&O cartridges have a lower output than other makes which can make a direct a/b comparison show the B&O as performing below that of another make. If you compare with a Shure cartridge it will sound much better initially.
What RIAA stage are you using – try playing with the settings, I have mine on a high output MC setting rather than MM and it sounds very good
