Reply To: New product launch – beosound theatre?
#8776
Steve at Sounds Heavenly
  • Topics Started 18
  • Total Posts 167
Hi Frank,
The key to this is whether the Theatre has auto line sensing in the same way that other Mozart speakers do. If so, then yes, you will be able to press CD on your remote control and the Theatre will switch to the line input automatically.
I hope to be able to test this in a couple of weeks time when I can get a proper change to try out the Theatre for myself.
Kind regards, Steve.
