Reply To: New product launch – beosound theatre?
#8757
frankmj
  • Elsinore, Denmark
  • Topics Started 0
  • Total Posts 6
Hi Frank, Beosound 3000 doesn’t need the speaker sense adapter, this is just needed for Beosound 9000 and Beocenter 2, as these units revert to option 0 (no remote control reception) when Beolab speakers aren’t connected. Kind regards, Steve.
If I connect my BS 3000 to the BS Theatre the way you described, with the powerlink adapter, and I want to play a cd. Is there an easy way to use the Beoremote One to start the cd on BS 3000 and activate the BS  Theatre  with just one keypress on the remote?
/frank
