8 September 2022 at 19:59
#27215
For IC101 and IC201 the pin voltages are the same
Pin28 – 13.51v
Pin5 – 0.040v (play) 0.027v (stop)
To check for the signals, I’m using the tape with the recorded calibration tones. This makes it easy to distinguish a signal from the background noise.
The plot below is the Pin4 input for the left (top/yellow) and right (bottom/magenta) channels
Here is a close-up of the Pin4 left channel with some measurements.
Glitch
