7 September 2022 at 07:08
#27236
Hello styppen, they are called
and are indeed adjustable (I took one from my 8000):
But if you cannot find the real ones, maybe you can find some short, flathead M5 bolts (called thumbscrews) and stick a rubber protector on it (one like this:)
Then you will still have the possibility to adjust the stance.
Good luck! Johan
