Reply To: Beo4 and beolink converter 1611
#8297
Millemissen
GOLD Member
    • Flensborg/Danmark
    If I understand your question right…..
    You don’t!
    The 1611 was created to convert the old MCL system to the (then) newer ML system.
    The BL3500 is a dedicated link speaker that needs a master (audio or video) to be used.
    If setup right, you can draw on the sources from e.g. an audiomaster/the sources there (radio/cd……).
    You control the BL3500 with the remote – have a look here:
    https://www.beoworld.org/prod_details.asp?pid=373
    • This reply was modified 1 year, 7 months ago by Millemissen.
