Reply To: New product launch – beosound theatre?
#8234
Steve at Sounds Heavenly
  • Topics Started 18
  • Total Posts 171
Yes, there is an analogue audio input via the USB-C port, this needs an adapter from B&O (part number 6271374).
This cable will connect from one of the Powerlink outputs of the Beosound 9000 or Beocenter 9300 to the 3.5mm line adapter:-
https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-harmony-eclipse-horizon-avant-ng-2017-on-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Please set the Beosound/Beocenter volume to a high level (50-75%) to give you the full range of volume control from the TV remote or B&O app.
You then just need a Speaker Sense Adapter for the Beosound 9000 (this plugs into the other Powerlink socket on the Beosound 9000 to allow it to accept commands from the B&O remote control without having B&O speakers connected):-
https://soundsheavenly.com/bang-olufsen/141-2309-beosound-9000-speaker-sense-adapter-gives-remote-control-functions-when-no-speakers-are-connected.html#/18-colour-black
Kind regards, Steve.
