August 5, 2022 at 12:45 pm
#7405
Is it really just as simple as that to change the voltage input?
Yes it is..
Most older B&O products use transformers with at least two primary windings. When these windings are placed in parellel then it uses 110 volts and when in series its 220 volts..
In this case they have gone beyond or extended the two primary windings to allow voltages of 100 & 120 volts with 230 & 240 volts.
