Reply To: A question on circuit board from my beolab 6000
#7402
mojofml
  • Topics Started 3
  • Total Posts 9
You’d have to remove both the bridges (i.e below each 120V label) and replace across the 240V. If you consider that the transformer winding terminals are numbered 1 to 8 from the left, then for a 240V supply you need 1 to be connected to 5 (hence the bridge), with the input supply connected to 4 and 8. (That’s from the service manual – avail to Silver and Gold Members!)
Thanks for your advice and the silver/gold material!
Is it really just as simple as that to change the voltage input?
Thanks!
