Reply To: Beogram 4002 dust and lowering arm problem
#7361
jensenfan
  • Topics Started 1
  • Total Posts 3
Thanks for your answer ! The lamp on the arm turns on. Another question: what other mechanism would prevent the system to lower the arm, for example if the LP is not mounted, or something else is detected ?
