Reply To: Beosystem 2300 Doors Won’t Close
#7350
Guy
  • Warwickshire, UK
  • Topics Started 4
  • Total Posts 193
+1 for the rubber belt – I replaced it on mine and it solved the problem.
You can get the correct belt here: https://www.beoparts-shop.com/product/belt-for-beomaster-6000-ouverture/
You could also try a little silicon lubricant in the runners (apply with q-tip) but to be honest all you are doing is making the belt’s job easier.
  • This reply was modified 5 days, 10 hours ago by Guy.
