Reply To: BeoGram 1000: alternative RIAA PreAmp ?
#7348
ajames
  • Topics Started 3
  • Total Posts 12
I had one built into a 1200 when I bought it second hand – i worked ok but the volume can be a little low for the SP pickup. There are loads of modules around but I ended up using it with an external amp with variable output. My main concern is that you don’t know how it’s good it’s going to be until you build it. Also you have to build in some sort of power supply, which means adding a transformer and other bits into the cabinet – all of which increase the chances of hum.
I’d also be interested though if someone has built one in and it works well.
