Reply To: Beosystem 2300 Doors Won’t Close
#7344
TheIdahoan
  • Topics Started 1
  • Total Posts 4
Thanks for the suggestion, and that could certainly be it.
My intuition is that because the doors open so easily, and don’t seem to struggle at all, that the belt seemed unlikely to be the cause.
More like when your garage door gets halfway down, you trip the sensor and then it goes back up.
Anything to that, or should I just go ahead and replace the belt?
