Reply To: Beogram 6000- restore and fix ground issue
#7332
ccamargo
  • Topics Started 1
  • Total Posts 2
Thanks Martin for prompt response.
indeed no connection between ground and chasis, I just wander why in the service manual explicitly refer to do the measurement to chasis…. Anyway, it is good to get confirmed I do not need to worry about that anymore. As you suggest I will start splitting circuits and check which part is causing the issue, I will report any findings here, any other ideas are welcome.
Christian
