Reply To: Update of Beovision 7
#7300
Rudiriis
  • Topics Started 2
  • Total Posts 4
One of the tasks the BM 7 Adapter does, is to receive the IR signal from the B&O remote and translate this to the IR signal to the TV. I can tell, every TV has own command set, so you choose the TV by a setup command from the B&O remote.
We have implemented hardware to send very strong signal to the TV – actually I have seen at B&O dealers (who sell our product) that every TV in the room react to the signal, so this is not a problem.
We have also added 2 receivers for IR signal from the B&O remote – one at each site of the box to get the signal.
Sunshine is the most difficult part with IR, as this will interfere – but normally TV’s are not close to windows (with sun), as you can not see the screen then 🙂
Normally the IR – in general – is running very well.
Best regards Rudi
  • This reply was modified 6 days, 8 hours ago by Rudiriis.
