Reply To: CRT – Visual issue on MX8000 (with 576i?)
#7274
premiumverum
GOLD Member
  • Netherlands
  • Topics Started 0
  • Total Posts 2
Looks like an interlacing problem. Can you change output resolution on the PS2 and PS3? Or the refresh rate?
I doubt you can change any useful setting on the MX8000
Refresh rate should be 25 or 50Hz.
Resolution 576i or 576p or PAL (I assume you are in europe?)
