Reply To: New feature: B&O Radio can now be used by ASE products
#7150
Gaea
GOLD Member
  • Topics Started 2
  • Total Posts 12
I think it indeed depends on what format each radiostation is broadcasting in.
For example the radiostation Soulradio has the following broadcast url’s;
http://listen.soulradio.com/soulradio.pls
[audio src="http://listen.soulradio.com/SOULRADIO.mp3" /]
http://listen.soulradio.com/soulradio-aac.pls
http://listen.soulradio.com/SOULRADIOAAC.aac
We don’t know wich url B&O radio and Tunein are using to put through
But one could assume that B&O uses a higher quality stream if it it availlable.
