Reply To: Changing fabric on Beovox S120
#7129
sonavor
  • Topics Started 0
  • Total Posts 14
I have a post on the old version of the forum that shows doing that.
I will try and find it and post the link.
You have to be very careful with the aluminum trim and just bend it a minimum amount to release it.  Otherwise, bending out straight will most likely cause the trim to break off at the bend seam.
-sonavor
