Reply To: BeoSound 3200: is the AUX connection IN and/or OUT?
#7122
KolfMAKER
  • The Netherlands
  • Topics Started 9
  • Total Posts 51
Thanks for referring to Peter Pan’s diagrams Guy, that made it clear!
I like the visual way of understanding the pin layout. In the end, it’s easy to make a mistake if you don’t understand the interpretation of sides: male/female and pin/hole side or solder side.
So a picture like Peter Pan is using, helps a lot:
Schermafbeelding 2022-07-28 om 11.26.07
