Reply To: BEOGRAM 5500 Scraping Sound… Any Ideas?
#7118
Die_Bogener
  • Topics Started 1
  • Total Posts 35
The beograms are very old hardware, they become lower and lower… quite normal, it can be adjusted easily.
And a new belt pulls on the left side additionally, lowering the left side of the platter.
There are 3 springs on the subframe. You only need a screwdriver and a good eye for adjustments.
Just remove the white platter cover and you have access to the springs. It is not necessary to open the deck like on the picture… just to show the springs…
Martin No.2
